- Mute
- Permalink
- Report
I have this existing tag (which is attached), which is used in our Life Safety plans.
The top number is the egress door number which is manually entered.
EGRESS is static text.
The name of the room - in this case PLANT - is also manually entered. I would also like the tag to be able to see and show the name of the room - less typing. Would be possible to add a Room Calculation point to this tag so that it can see the name of the room?
The 200 is the result of the calculation for the number of occupants allowable by the door width - also manually entered. The challenge is to plug in the formula
(panel width - door thickness) divided by .2 = number of occupants that can go through that opening
to calculate this value. I did think of converting this to a door tag so that it may see the clear width of the door.
I would appreciate any help possible to get this done. Thank you!
Rina Sahay
Autodesk Expert Elite
Revit Architecture Certified Professional
