Trouble with lattice work in the parametric window
tharushadd
Message 1 of 16
tharushadd
I am very new to Revit.
Can anyone guide me how to model a parametric window family as in the attachment. I can model everything except for the timber lattice, there in the window as a component. I just want the lattice work to be 1"x0.5" timber stripes at an 45° angle ( That doesn't have to be parametric)
Replies (15)
Message 2 of 16
dzanta
I would create those 4 panels as a 4 separate extrusions with a wood lattice model pattern (diagonal lines).  Ensure you align and lock the 4 sides to the reference planes that control the framework too.
Dzan Ta, AEE, ASM, ACI.
Autodesk Community | Twitter | YouTube | Facebook | LinkedIn |
Win 11 Pro/DELL XPS 15 9510/i9 3.2GHz/32GB RAM/Nvidia RTX 3050Ti/1TB PCIe SSD/4K 15.4" Non-Touch Display
Message 3 of 16
Do you mean "muntins".  If so, Revit has a dozen or so Muntin Families in the OOTB library. Windows Folder=>Nested Families Folder=>Muntins Folder.
...you can also go to Pella or Marvin and download their Revit families.  Most have Muntins in them in all sorts of configurations (e.g. Prairie, Diamond, etc., etc.)
Message 4 of 16
tharushadd
Thank you very much, but how to have a 'wood lattice model pattern'...any video tutorial on internet...so that I can follow..
thanks again
Message 5 of 16
dzanta
after you make the 4 extrusions, select them and go to properties palette...you will see material parameter.  click inside this to assign a Model material pattern....choose the diagonal line pattern
Message 6 of 16
Still trying to figure out what is being talked about here.
Is it Lattice like this?
Or, Lattice like this (e.g. Muntins in a Diamond Pattern)?
Or, Lattice like this (e.g. Diagonal Crosshatch Surface Pattern)?
Message 7 of 16
tharushadd
d.jpgActually something like this....as shown in the window drawing
T
Message 8 of 16
I like the pattern. What is that? A screen?
Message 9 of 16
tharushadd
Yes a screen...
Message 10 of 16
A screen???  Well now...isn't that special.  Smiley Wink
Message 11 of 16
Barthbradley,
How would you actually create a modeled parametric lattice like the wood one here?
Seems simple but anything on a diagonal always complicates things.  I need to model this exact thing for a rendering of a "lattice top wood fence" - I'm thinking it would be a nested adaptive component??
The 45 degree lattice work would need to fit inside a rectangular boundary.
Message 12 of 16
I would use a material with a diagonal cross surface model pattern instead of modeling it.
Message 13 of 16
Are you talking about the wood lattice I showed above?  You could do this with a curtain wall. No panels, just mullions.  Maybe 1" x 1/2" slats, with beefier border mullion frame.  But if you are talking about the Screen you showed above, I'd find an OOTB "Metal Screen" Appearance Asset for Rendering, and then use a plain old cross hatch Surface Pattern for Elevation Views, etc.
Message 14 of 16
Yeah, that's a bummer - I had my fence all parametric and ready to go, last was the parametric lattice.  If I had started it all as conceptual massing, I probably could have done it with dividing surfaces.  Oh well, that's a headache for some other time.  Guess I'll do a .PNG material with voids.
Message 15 of 16
I thought you asked about windows.  If it is a fence, just use a curtain wall with panels by a different curtain wall type, and rotate the grids 45 degrees.
Still, there is no practical reason to model the lattice. A material with cut-out should work nicely.
Message 16 of 16
I think he means Curtain Walls with Empty Panels -- which is what I suggested.
