Trouble with Invisible Line
Message 1 of 16
I have used the linework tool to change some lines to invisible lines.  Everything looks fine on screen but when printed, the lines show up as a screened hidden line.
Thanks in advance.
Replies (15)
Message 2 of 16
XXalessio.amodioXX
We do not have any crystal ball. if you do not post image,project,family we cannot help
Message 3 of 16
Sorry,
this is some shots from screen amd PDF
SCREEN
 PDF
Message 4 of 16
syman2000
What PDF driver are you using? Adobe, CutePDF, PDFforge, Bluebeam?
Message 5 of 16
 I AM USING : PDF ARCHITECT
Message 6 of 16
XXalessio.amodioXX
They seems some kind of Steel Baces (?) with some thicnkness.
Have you tyied Join Geometry?
Message 7 of 16
Yes they are.  The horizontal one, do not has an angle but the others they do have.
I cut in a height that I see those lines that I am trying to hide.
But this does not happen only with steel elements but everywhere I used Invisible Line.
Message 8 of 16
syman2000
Have you try masking region to hide those object and see if those line show up in PDF?
Message 9 of 16
I just did...but still masking region has it's own perigramme that I do not want to be shown.
Message 10 of 16
syman2000
I think it is your PDF driver and not Revit issue. Because I use adobe and Bluebeam, it won't have that issue. So you may want to try another PDF output like
CutePDF - https://www.cutepdf.com/index.htm
PDFforge - https://www.pdfforge.org/
BullZip - https://www.bullzip.com/
Message 11 of 16
XXalessio.amodioXX
I use <Invisible line> for the braces too. It works properly. Your issue must be on PDF exporter as the others say
Message 12 of 16
Thank you a lot. Can you please tell me which PDF Creator you are using?
Message 13 of 16
Message 14 of 16
XXalessio.amodioXX
PDF Creator 4.2.0
Message 15 of 16
Thank you a lot.
Message 16 of 16
Thanks a lot.
