This over decade long stringer problem is still here. Revit costs thousands of dollars a year and all they offer on next year is +1 to a title. Oh, and we got slanted walls.
So you might already know that stairs stringer has mutually exclusive options: open and closed. Closed one allows me to chose profile, but profile has no offset. The open one has offset but no profile selection. I have seemingly simple stringer design requirement. Geometry below stringer is railing family and looks like crap. Can anyone help out to solve this?
Thank you.
I might use a Wall and Wall Sweep to accomplish -- not Stair Supports.
...and cut the bottom of the curved Walls with In-Place Void.
Railings will host to top of Wall.
FWIW:
Designing with Custom Railing Panels in Revit | Autodesk University
Actually, maybe supports would be the way to go here. Let's take a look at what you've done. Post the File.
File is here. I "solved" it with additional in-place geometry. But if my client would like to move stuff around I will need to redo it. This is not what I expect from CAD complex in 2021.
Thank you for trying to help me with this.
