Trouble uploading Revit model (2015) to Autodesk viewer
I need to present my Revit 2015 model to a homeowner's association. I have tried to upload one file (239MB) to the online Autodesk viewer and it has failed 4 times. I then stripped the down model to 140MB but I'm having the same problem. Are there any suggestions about what I'm doing wrong or is there a step I'm missing? There are no supplemental files as far as I'm aware of, so I answer no to uploading additional files.
Or, is there a way to view a Revit model besides a) the Autodesk viewer  or b) downloading and installing a trial version of Revit?
Thank you,
Deb Auten
hi, have you try to update your file?
but the best way to show a model is to use BIM360
