Hello
I shall begin with the issue of "Families". Specifically "Generic model" and "Generic model void".
Below you may find some screenshots.
what exactly happened.
I need create "family" with this 2 objects. After then i need to move it near to other object.But i get some warning.
I need keep this small distance between them. I do not mind about "UNjoin" its.
But Revit want to delete "family" any way.
it's hard to explain. PLS check the screenshots.
Solved by Luiscko. Go to Solution.
