Tree does not appear on 3d view even if checked in visibility graphics
LanggamanXavierMassed
Message 1 of 11
I tried to put a tree from Site Component (Massing and site tab) and I cannot see it even if I check visibility graphics.  the component is an original tree and not from any external reference.  View is set course to Fine - still no show, thanks
Replies (10)
Message 2 of 11
bin
It’s probably not the reason but the trees are under planting category.
Message 3 of 11
There could be several reasons the tree does not appear in the view.  Here's a list of 33. Keep it handy for future use.
Missing something in a Revit view? 33 steps to find stuff
https://www.ideateinc.com/blog/2013/01/missing-something-in-revit-view-33
Message 4 of 11
ennujozlagam
have you try to change the detail level to FINE and or it was hide in 3D view, activate your bulb icon and unhide elements and see if helps. thanks
Message 5 of 11
still does not appear, same thing happening with a furniture, bulb, reveal, everything still does not show.  Only shows in plan
Message 6 of 11
ennujozlagam
is there anyway you can share the file so we can check. or send link to my email add. or any view template assign change to none. thanks
Message 7 of 11
Check Phasing of the 3d view. Is it the same as the plan view's?
Message 8 of 11
None of the 33 applied?  Wow. Maybe there's a 34th out there that someone can share.
Message 9 of 11
@LanggamanXavierMassed: You sure it isn't a bad family?
Message 10 of 11
i think it was, I didn't remove it, just restarted the file and finally it appeared the next day after, revit is so weird, tnx btw
Message 11 of 11
maviveros2
Community Visitor
Community Visitor
I was in 3D and had the Section Box active, I unchecked the Section Box and the trees appeared, then I reactivated the Section Box and the trees are still there. Hope this helps.
