Can't render, takes too long and keeps going from 0% to 1.6%
Every time i try rendering, it doesn't work. I tried with multiples sizes, regions and it just doens't render. No firewall barriers, using a geforce 940mx as gpu. Tried changing lights too.
L.Maas
Revit does not use the GPU for rendering.
You are not getting any errors?
Have you tried a different (e.g. new small) project and tried to render that?
Have you checked the journal file and see if something is mentioned in there?
Hardware in order (hardware specs, enough free space on your drives)?
Louis
Please mention Revit version, especially when uploading Revit files.
I just noticed it was the scale, 1:1. God that's what i get for having a short atention span. Thanks!
