trapezoid wall and column are join issue
7 REPLIES 7
Message 1 of 8
688 Views, 7 Replies
Hi everyone. I have a problem. How to this walls join to the column.
7 REPLIES 7
Message 2 of 8
Alfredo_Medina
and what is the problem?
Message 3 of 8
in reply to: Alfredo_Medina
The problem is that the columns and walls do not join as in the picture attached.
Message 4 of 8
cbcarch
Try making the wall and columns the same exact Material, as a test.
Also, try using Join Geometry.
Cliff B. Collins
Registered Architect The Lamar Johnson Collaborative Architects-St. Louis, MO
Message 5 of 8
in reply to: cbcarch
Actually what I want to do is not merge, but instead of creating a new family, I am looking for a practical solution to extend the column towards the angled wall.
Message 6 of 8
cbcarch
Not sure why you don't want to make a new Column Family--it would be very fast.
You could even give the angle a dimension instance parameter so you could adjust the angle of the column in different walls that are at different angles.
Cliff B. Collins
Message 7 of 8
I will try to create a family using the angle parameter. thank you.
Message 8 of 8
I'd talk to the Architect about this. Looks kind of nasty.  Maybe the solution will be moving the Wall or moving the Columns, if that is an option.  I'm sure there are building codes that will influence the decision as well.
Forma Design Contest
