transparent watermark
Message 1 of 11
i want to create watermark for my drawings. i insert it , but the Letter and it's background is covering my drawing.
can i make the letter transparent in revit 2020 ??? image attached
Replies (10)
Message 2 of 11
_Vijay
yes you can...as below snip.
Vijayakumar
Head of BIM
Did you find this post helpful? Feel free to like this post.
Message 3 of 11
Hi Vijay
Thanks for your reply. Its works but please see attached photo. can make that letters transparent
Message 4 of 11
Message 5 of 11
Can we do without auto cad involve
Message 6 of 11
Photoshop is another way.
Awhile ago there was Free Add-in that claimed it could it.  Dunno. if it's true.  Search the Store for it or something simular.
Only other idea I have, would be trace the  Text in a Legend View using Filled Regions  and make it  transparent. Then place this Legend View on multiple sheets.
Message 7 of 11
martijn_pater
For text you can use an outlined type font ie. Swis721 BlkOul BT and place it on the sheet (could be a generic annotation symbol).
Message 8 of 11
syman2000
I would use Model text
First create the textFirst create the text
Next crop the view
Next crop the viewNext crop the view
Right click on the model text and override it by element
Right click and override by elementRight click and override by element
Set it to transparency 60% and half tone
Set it to halftone & 60% transparencySet it to halftone & 60% transparency
Drag it to the sheet and you will see watermark
Drag it to sheet and you will get watermarkDrag it to sheet and you will get watermark
Message 9 of 11
Watermark is best done in a PDF program.  Much more versatility and your working drawings are clean.
Message 10 of 11
georgehobel
that's the way the pro's do it....
George Hobel
Reflections of Charlotte
Residential Building and Design
Message 11 of 11
You can add watermark on ToolsBlast.com. They have a free, simple and very solid tool for watermarking - it supports also batch processing, and always generates waterark proportional to the photo size - this looks great. The direct link to the tool - watermarking tool.
