Transparent glass in elevation on door family
CT36801
Message 1 of 10
CT36801
I am not sure how to accomplish this.
need glass in this folding door family to be slightly transparent to show beyond.
like the 3D:
Replies (9)
Message 2 of 10
Message 3 of 10
CT36801
I just used that trick to get the opening to appear transparent when the door is set to show as open.. but what about the glass?
Message 4 of 10
Is the Glass Material Transparent?
Message 5 of 10
CT36801
yes - see 3d snip.
Message 6 of 10
Message 7 of 10
handjonathan
Hi @CT36801
Thanks a lot for posting your question to the forums!   Has the solution suggested by @barthbradley helped with your issue?
We look forward to hearing back from you with more information so we can help you as a community! 
Jonathan Hand
Technical Marketing Manager | Construction
Message 8 of 10
CT36801
I haven't yet found a satisfactory solution to this issue. I'm not sure if it's possible unless done with a 3D view in elevation.
Message 9 of 10
Did you read the instructions in that Link I provided?
Have you tried overriding the Window/Glazing graphics in View to apply a Transparency?
How about turning off the Glass Subcategory in the View (or whatever Subcategory, if any, the glazing geometry is in)?  That's a legit, documented workaround. I think it was also mentioned in that Link.
Post your File.
Message 10 of 10
If you want only the glass semi-transparent then using 3D elevation is the easiest way.  If you want to do it in 2D elevations then use a shared nested family for glass components in the family, then create a filter to override the transparency of glass components based on the family name (or something unique).
