Transparency glitch Graphic Display Options
I'm working in a student version of Revit 2017. I was exploring the transparency feature in the graphic display options, but when I tried to reset the transparency back to 0, the wireframe lines remain present in all 3d views. I have tried re-downloading the software, and even importing it into a 2019 version, but the issue persists. It is very irritating to work with and it distorts a number of graphics as well.
Replies (14)
I think it's unlikely to be a glitch. What is 3D View's Visual Style set to?
It doesn't matter what style it is in, all lines in the drawing show in realistic, consistent colors, hidden line, and shaded. I've even tried resetting all settings to default but to no avail.
Okay, let me ask you this: is the same thing happening in new Projects -- or is it just happening in one?
It is only in this instance of the project file. The older versions of it display properly but a significant amount of work has been done since. New projects also work fine, I am worried the file itself might have an error maybe.
Okay, so the "glitch" sounds like it's with the file, not the software.  Let's try an Audit. Are you familiar with the procedure? Just Open the Project with Audit checked.
Yea I tried to audit as well and it didn't fix the issue.
Okay, let's have a look at it. Post the file?
Here is the file, thank you for the help
Well, I don't readily see an issue.  All the Views that I checked are responding correctly to different Visual Style settings I apply.  Give me a specific 1-2-3 workflow to follow to try and duplicate your issue.
BTW: do you have Hardware Acceleration turned on or off?
Okay, it started after this:
I had the current view set as 3D with visual style set to realistic. I used the transparency slider to try and work on a part of the model that is rather dense, and when I reset the slider to 0, the surfaces returned to being opaque but it is as if the wireframe visual style is permanently enabled as a layer on all visual styles. So, the edge lines of every object/surface are always visible. In the attached images the 3D style is supposed to be Consistent Colors or Hidden Line but it does not hide any of the lines in the drawings.
I can't seem to replicate the issue at my end.  I do notice something else peculiar in your screenshot. The look of the Transparency Slider Bar.  It's blue.  Could relate to issue.
...edit: well actually, your whole GDO Dialog Box is different.  Is it like this in other sessions of Revit?
Yours:
Mine:
@ToanDN: Any thoughts?
The default {3D} view is corrupted, even the section box is tilted.  Other views are fine.  Simply delete teh {3D} view and recreate a new one from the 3d home button.
Yup that was it! The new 3D view is correct. I can't believe it was so simple to fix. Thank you both for your help.
Thanks for helping @ToanDN . What's strange to me, is that mine wasn't corrupted. I'm guessing yours was.  What would cause that?  3 different machines with 2 different results?  Hmm?  Head Scratcher.
Type a product name
______
icon-svg-close-thick
Cookie preferences
THIRD PARTY SERVICES
icon-svg-hide-thick
icon-svg-show-thick
Qualtrics
Akamai mPulse
Digital River
Dynatrace
Khoros
Launch Darkly
New Relic
Salesforce Live Agent
Wistia
Tealium
Upsellit
CJ Affiliates
Commission Factory
Typepad Stats
Geo Targetly
SpeedCurve
Qualified
icon-svg-hide-thick
icon-svg-show-thick
Google Optimize
ClickTale
OneSignal
Optimizely
Amplitude
Snowplow
UserVoice
Clearbit
YouTube
icon-svg-hide-thick
icon-svg-show-thick
Adobe Analytics
AdWords
Marketo
Doubleclick
HubSpot
Twitter
Facebook
LinkedIn
Yahoo! Japan
Naver
Quantcast
Call Tracking
Wunderkind
ADC Media
AgrantSEM
Bidtellect
Bing
G2Crowd
NMPI Display
VK
Adobe Target
Trendkite
Hotjar
6 Sense
Terminus
StackAdapt
The Trade Desk
RollWorks
Your experience. Your choice.
