Transform gizmo
Transform gizmo
Message 1 of 9
Transform gizmo
I installed Revit 2019 and the usuall transform gizmo seems to be gone? Does anyone know how to activate it?
Replies (8)
Message 2 of 9
"Transform Gizmo"?  What are you referring to?
Message 3 of 9
cbcarch
I think the gizmo (sim. to 3dsMax) only appears in the Conceptual Massing environment, not the family editor.
Cliff B. Collins
Registered Architect The Lamar Johnson Collaborative Architects-St. Louis, MO
Message 4 of 9
Thanks for replying. The screenshot is from a normal 3d view, not in family
editor.
Message 5 of 9
I'm referring to the transform tool that appears on every object when
selected. Its the blue, green and red widget with x, y, z axis that lets
you move, scale or rotate an object (all views including 3d) in any of the
given directions.
Message 6 of 9
RobDraw
I've never seen that. You must be thinking of another platform.
Rob
Message 7 of 9
It's in massing environment (project or family).  Don't know why it's not for OP.
https://knowledge.autodesk.com/support/revit-products/learn-explore/caas/CloudHelp/cloudhelp/2015/EN...
Message 8 of 9
@Anonymous : are you saying that when you edit the form and select and edge or surface, the "Gizmo" doesn't appear at all?
Message 9 of 9
cbcarch
Are you editing a Conceptual Mass? Or is that just an in-place family in the project environment?
Cliff B. Collins
