Transferring Legend Views
13 REPLIES 13
Message 1 of 14
31263 Views, 13 Replies
Is there a way to transfer legend views from one project to another?
13 REPLIES 13
Message 2 of 14
No, you cannot save a legend view using the Save to Library > Save Views in the File menu, but you can copy and paste the components or symbols from the legend view into another projects legend view. I recommend creating or placing your legend views into the project template file.
Mel Persin, AIA
AEC Technology Consultant
Technology to Visualize and Realize Solutions
Model for the Future/Drafting in the Present/Building on the Past
Message 3 of 14
Copying and pasting is the approach I ended up taking... I was just hoping for a more graceful solution! The legends are all going to end up in the template file - it's just that they were not all finished when several projects were started. Now that they are, I had to update the project files.
Anyway, thanks for the response.
Message 4 of 14
dreesera
In Revit 2021, I was able to copy Legend elements to a new drafting view and save the view from Revit to import into a different project.  Then copy/cut then paste those elements into a new Legend view under the desired project.
Not sure if there was limitations in earlier versions of Revit for doing this.
Message 5 of 14
Bramdejong1985
There is actually a new add-in I found out this month called Transfer Legend.
It basically allows you to copy specific and/or all legends (checkbox for each one) from a linked file, to your own project.
So you could link a Revit file you need the legends from, and un-link after taking the legends.
It had helped me from doing tedious work.
Message 6 of 14
pyrevit has a command that does this also
Message 7 of 14
Pyrevit does do this but it does not seem to copy the reference planes sadly.
Message 8 of 14
in reply to: curtisridenour
Since Revit 2022, you can copy paste Legend view directly from one sheet of one project to another sheet of another project with everything intact.
Message 9 of 14
curtisridenour
Yes, but my template is in Revit 2021 sadly.
Message 10 of 14
Too bad then.  If I were you I wouldn't invest too much time in the old template and prepare to move to a newer one.
Message 11 of 14
curtisridenour
in reply to: ToanDN
i wish our client would allow us to.
Message 12 of 14
What I did prior to Revit 2022: add both ref planes and detail lines to Legend views so that when transfer using pyRevit, I can recreate the ref planes based on the detail lines.
Message 13 of 14
curtisridenour
in reply to: ToanDN
I just did the same thing. I am resisting the urge to write a dynamo script to copy the reference planes to lines and lines to reference planes.
Message 14 of 14
DEP_ABC
There is two ways to approach this from my knowledge.
A method - works in RVT22 and later versions since from RVT22 we can copy Sheets with elements on the sheet.
B method - works in RVT21 and older versions, but can be used in later versions, if you don't need sheets with Legends on it.
X - project with Legend(s)
Y - project that missing Legend(s)
Both projects needs to be open in same Revit session.
A method:
1: X project - Place legend(s) you want to copy on the sheet(s)
2: X project - Select sheet(s) in the Project Browser, hit CTRL+C.
3: Y project - open Y project and hit CTRL+V, klick OK.
Sheets will be created, legends will appear on sheets and in Legends section.
B method
1: X project - Place legend(s) on the sheet(s).
2: X project - Select legend on the sheet hit CTRL+C. (In here Revit copies Legend as Viewport)
3: Y project - open Y project and on any sheet, hit CTRL+V, klick OK and either you can place the legend(and delete) or you can cancel command, legend should be already copied to your Legends section.
Hope everything make sense what I wrote 😄
Let me know if there is mistake so i can fix it 😉
Forma Design Contest
