Transferring Layer Styles from CAD to Revit
Message 1 of 15
Hello, I am looking to transfer our CAD layer styles into Revit. I realize in Revit you can change the way layers export and their properties manually, but we have hundreds of layers and styles that we have defined and want to continue to use in Revit and doing this would be a huge task that many of us don't have time for. Is there some way to convert our AutoCAD layer styles and implement them into Revit?
Replies (14)
Message 2 of 15
RobDraw
Wait, what? Why?
This just sounds like a disaster waiting to happen. Revit is a totally different animal. There are no layers in Revit.
Rob
Message 3 of 15
Layers??? Revit doesn't use them.
...and HUNDREDS of Line Styles???  Wow! I agree; that is going to be some undertaking.
Message 4 of 15
cbcarch
Are you trying to create a Custom Layer setting for EXPORTING to Cad from Revit, that matches the old Cad Layer Standards. ???
https://knowledge.autodesk.com/support/revit-products/learn-explore/caas/CloudHelp/cloudhelp/2016/EN...
Cliff B. Collins
Registered Architect The Lamar Johnson Collaborative Architects-St. Louis, MO
Message 5 of 15
RobDraw
If that is what was meant, then the terminology totally lead me in the wrong direction.
Rob
Message 6 of 15
I interpreted the same as @cbarch.
Message 7 of 15
Well, I interpret it the way @Anonymous meant it.
Message 8 of 15
RobDraw
That's funny, I didn't think the OP mentioned those.
Rob
Message 9 of 15
RobDraw
Key statement there. I got a bit mislead by the title of the thread. I thought they were importing .dwgs.
Rob
Message 10 of 15
Well, it's funny you say that. He didn't say "Line", but if you think about, what other Layer property, besides Linetype and Lineweight, would you want to "transfer" to Revit?
...Line Color?
Message 11 of 15
RobDraw
I thought he was referring to layer states, but, now that you mention it again, line styles does make sense when we put it in the context of exporting back out to AutoCAD. I think.
Rob
Message 12 of 15
RobDraw
Reset. No more guessing at what the OP really means.
Why is the never time to do it right but always time to do it over?
By "layer styles" do you mean the setings assigned to each layer, i.e. layer properties?
Rob
Message 13 of 15
Yes exactly, sorry if my post was confusing. I am not well versed on this topic as I'm fairly new to Revit and am just trying to see if it's even possible.
Message 14 of 15
RobDraw
Forget about it. There are no layers in Revit.
Rob
Message 15 of 15
samuel_felipeH9UGK
Community Visitor
Community Visitor
You can always try to Import the drawing (DWG) that has the Layers you have into Revit in any view that it will appear. The imported drawing should have all the layers being used in the model space for this to work. Then select the imported object and explode it. Delete the linework if you don't need them. Then check the Line Styles and you will find your layers appear as line styles.
