transfer single view template
kvfritz
Message 1 of 9
kvfritz
According to FAQ the view template transfer has been fixed. Not so. Using version 2018.3 and view template transfer fails with existing and new models. When will this be a working tool?
Replies (8)
Message 2 of 9
Atafs
Hi, I'm pretty sure this is not available in Revit.
what I would as a work around is create a new project and import your templates
then purge and delete (By going view tab, view templates, manage view templates) whats left of view templates until you only have the one then you need, and finally transfer templates from the new file to where you need it!
i hope this helps
Message 3 of 9
https://apps.autodesk.com/RVT/en/Detail/Index?id=1090472181312958476&appLang=en&os=Win64
@barthbradley - This reply has been edited by the moderation team as the link was no longer valid.
Message 4 of 9
Atafs
The link does not work!
Message 5 of 9
martijn_pater
Delete the other templates, safe as different file and transfer project settings?
edit: same answer was already given above, perhaps there's an easier way can't think of one though.
Edit 2: you could ofcourse recreate the view template settings in your project...
Message 6 of 9
Fails how?
Message 7 of 9
TB3
For those still running into this seemingly simple task of tranfering a specific view template between projects - the pyRevit extension "EF-Tools" offers this funcionality in a simple and straightforward way.
(pyrRevit is the best, for those not yet familiar with it - check it out! open source and great)
Message 8 of 9
MachielAEC
Was going to recommend the same - EF-Tools has this feature built in.
https://www.youtube.com/watch?v=sajVtSFRrOI
Machiel Odendaal
---BIM Enthusiast---
Message 9 of 9
Ian_H
To install EF-Tools you will need to install Pyrevit. Pyrevit has the ability to pick individual view templates and send them to another project. It's a tool I have used quite a bit.
