Hi All,
I'm getting the following error message when trying to insert a component
"A serious error has occurred. It is strongly recommended that you use Save As to save your work in a new file before continuing."
Several solutions:
Hi @Anonymous
Welcome to the Autodesk Community! I see that you are visiting as a new member ![]()
Can you check this AKN article for a resolution, and let me know if this helps?
I look forward to hearing from you.
Viveka CD
Designated Specialist - AEC, AR/VR Research
Autodesk playlists| Find Recommended Hardware| System requirements for Revit products| Contact Autodesk Support| Autodesk Virtual Agent| Browse Revit Ideas| Revit Tips/Tricks| Revit Help| Revit Books
I think the best way to know what has happened is to just read journal file and locate the moment right before the error.
