Is there a way i can transfer my Revit 2017 settings / file locations / keyboard shortcuts into Revit 2018 easily?
Solved by loboarch. Go to Solution.
Some of that kind of thing is stored in the Revit INI file. You can transfer that over and get most of the things you are looking for probably.
http://help.autodesk.com/view/RVT/2018/ENU/?guid=GUID-9ECD669E-81D3-43E5-9970-9FA1C38E8507
It is unbelievable that Revit does not have the ability to backup user settings and transfer them to a new release or re-install. Using the Revit.ini file is ridiculous and does not address all user customization. Get with the program and develop a user settings backup and transfer function. To see an example of how this is done look at Solidworks. This has been a basic feature for 10+ years. I consider it a waste of my time to copy/paste Revit.ini files and export import shortcut xml files. I would settle for a third party program that accomplishes this, it should be a simple task for any user. It needs to be published as part of the upgrade process with the release of each annual version.
@Anonymous,
I have always been frustrated I can't save my settings for the Quick Access Toolbar configuration I use. But all my options with the Revit.ini are covered on installation and my keyboard shortcuts take 2 seconds to import.
What settings are you looking to transfer that you can't accomplish with the Revit.ini?
This should not be marked as solved, it is not!
I just installed v2019 of Revit and AutoCAD. You know what AutoCAD has?
A transfer settings system.
I am fairly new to Revit and wanted to explore the possibility of exporting user settings to an installation of Revit on another computer (for a different user), like you can do with Autocad. I had a look into the Revit.ini file but I noticed it stores information about user ID and a list of recently accessed files. I suppose I would remove these lines when copying the file onto another computer. Is there anything else I would need to remove to make sure it will work for a different user (also on a subscription license)?
Is there a way of importing text types between different Revit installs of the same version (2019)? Is there a way of importing them between different releases, say 2018 to 2019?
I'm not sure if anyone from Autodesk is monitoring this thread but I was reluctant to open a new one when this one could easily be revisited. Apologies if that isn't the right thing to do.
This issue is ongoing and Revit pays it little attention. Copying the Revit.ini file blinding may have unintended consequences as certain lines of code are added or deleted with each new version of Revit. Autodesk recently added the ability to transfer user settings in AutoCAD, only took 30 years...
Look at the critical features that are helpful to transfer between versions:
Bottom line is: This case is not solved! Autodesk has a habit of marking cases solved because they have a crippled work-around. Truth is, Revit is 10-years behind comparable 3D modeling software like SolidWorks when it comes to user functionality. Every year there is an upgrade to Revit and they still have not bothered to create a simple Add-In to transfer user settings. Ridiculous!
