How to add walls in my wall tool ?
3 ANTWORTEN 3
Nachricht 1 von 4
370 Aufrufe, 3 Antworten
Hallo together, im working with revit since 3 years but in the past ive never had to adjust anything.
Now i have to work with Revit and have to adjust the standarts. can anyone help me how i get the standarts for working with ?
Tags (1)
3 ANTWORTEN 3
Nachricht 2 von 4
ennujozlagam
als Antwort auf: Anonymous
hello, what do you mean by this How to add walls in my wall tool ? can you explain more or go to Architecture > wall > wall: architecture > edit type > duplicate > structure > edit then  modify assembly to your needs. thanks
Nachricht 3 von 4
Alan.johnson1970
Walls are system families, so as  you either duplicate and edit what you already have or you can copy walls from another project file using Transfer Project Standards on the Manage Tab.
AJ.
Nachricht 4 von 4
aRcHiTeCt.JM
.... do you have your own template
... or do you work on the REVIT default template?
... if you have your own you need to go and re adjust it
... if you work on the default just open a new one and copy-paste the project
aRcHiTeCt.JM
REVIT EXPERT ELITE
➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ is it working for you ? ➪ ⇩ 'Accept as solution' ⇩ ⇦
