Total Counts in Schedule
5 ANTWORTEN 5
GELÖST
Nachricht 1 von 6
kodiTSM2
357 Aufrufe, 5 Antworten
I am trying to create a total column or cell for plan item data in a schedule. I've tried using a Totals footer but it shows nothing. For example, I have "Aaron's Beard" with a count of 30 and 46 and would like to have the schedule create a total. Is there a way to total counts in a schedule?
Tags (1)
Beschriftungen (1)
5 ANTWORTEN 5
Nachricht 2 von 6
als Antwort auf: kodiTSM2
Go to Format Tab and set that Count Parameter to Calculate Totals.
Nachricht 3 von 6
kodiTSM2
als Antwort auf: barthbradley
That worked. Thank you!
Nachricht 4 von 6
vitorbortoncello
A resposta te ajudou? Não esqueça de curtir e aceitar como solução!
Vitor Bortoncello | Arquiteto | Especialista BIM
aAutodesk Certified Professional
Nachricht 5 von 6
kodiTSM2
als Antwort auf: vitorbortoncello
Appreciate it. Do you guys know if it is possible to export just the plant name and total to excel?
Nachricht 6 von 6
vitorbortoncello
you can export to .csv
