When I put the 3D view on Hidden Line visual style, the toposurface shows up white. Any way one can change the white colour?
Solved by barthbradley. Go to Solution.
Override Graphics in View By Element, Category or Filter. It's the Surface Pattern you want to change.
Thank you for the response. However, any chance you could take a screen shot on how to do that please? I'm still learning Revit.
I used the Visibility/Graphics Overrides before (accessed by the Properties pallet), but I don't know what do you mean by (View Be Element, Category or Filter).
Topo surfaces can only show surface color (defined by the material's shading color) in shaded and consistent colors, not hidden.
Select the Topo in the View, right-click and press Override Graphics in View.
