TOPOSOLID
TOPOSOLID
arkitek2ss
TOPOSOLID
arkitek2ss
how do you get the toposolid to connect ALL or almost all points?
ABR_Kate
Hi @arkitek2ss
The screenshot you shared doesn't give us the full picture, so I'll need some more information to help you effectively.
  • Where did this data come from? Is it from a survey, an imported file, or something else? What's the file format (e.g., DWG, DXF, SKP, CSV)?
  • What is your final goal? Are you trying to get a surface or a toposolid?
When you work with points in Revit, the Toposolid tool automatically creates a triangulated irregular network (TIN) based on those points to form the surface. It doesn't necessarily "connect all points" in a sequential order but rather builds triangles to create the most accurate representation of the terrain.
If you're looking for a quick and accurate way to get topography, you might want to check out services like CadMapper or X-GIS. These tools allow you to download ready-made 3D terrain models with contour lines directly into Revit. This can save you a lot of time and help you avoid the manual hassle of connecting points.
Looking forward to your clarification!
imankassab2015
can you share the file and explain your main goal to help you by elaborating more with information
mari.shimode
Hi @arkitek2ss, how are you doing? Like the others said, it'd be great if you could share a bit more details on your question with the community. Thank you.
Mari Shimode
