Toposolid is a pain in the a... Spot Elevation Tool
Architektur23
Architektur23
I can't be the only one with this stupid problem?
In an elevation plan or in 3D, I have spot elevation heights marked... but as soon as I want to change the heights of the topo, all surrounding spots are gone with a stupid error that there are not valid anymore..
In the picture before and after i changed only ONE height (red circle) and all in the yellow circles are gone... how can i work with this?? Is it a bug or feature in revit 2024? Either way it sucks....
I don't have that issue. There must be something else going on. How are you changing the height of the Topo? Give us your step-by-step.
Also, try isolating the Toposolid in View and then placing your Spots Elevations. Then change the height of the Topo.
Architektur23
I click on the topo, change underlying element, mark on point and change the number value to another height... sometimes it works without deleting the spot points, but most of the time it doesnt...
It mostly works, if the spot point is exactly on a underlying point, but because you cant snap a spot point on that, its useless...
