Toposolid Graphics is shaking
bim.gedung.027
bim.gedung.027
Hello everyone, here am working with Revit 2025, and have an issue where when create objects far from the Revit startup location, they appear to shake and are inaccurate. It feels like an error. have to create objects that are far from the startup location because the exact coordinate point is located there. What should I do?
(view in My Videos)
azad.Nanva
No this is correct and have no problem, this is just too small , maybe can report as screen issue but not a real issue ,if you export to DWG you see this is percies a point not two or incorrect one.
