topography to floor?
8 REPLIES 8
Message 1 of 9
11547 Views, 8 Replies
Is there any way to create floor from topography that I created from imported dwg?
Thanks!
Amit
8 REPLIES 8
Message 2 of 9
cbcarch
Take a look here:
https://landarchbim.com/2015/10/21/make-hardscape-follow-topo/
Cliff B. Collins
Registered Architect The Lamar Johnson Collaborative Architects-St. Louis, MO
Message 3 of 9
Not a FLOOR, but you can do a ROOF and call it a "Floor".
Import the CAD you used to create the Toposurface directly into an In-Place Massing session, close out of the In-Place Massing Session and use the ROOF by Mass Face tool (Massing & Site Tab) and select faces of the Mass that was created from the CAD.
Works like a charm.
Message 4 of 9
in reply to: cbcarch
Thanks for posting that link @cbcarch. I hadn't seen it before.  Do you know right off hand if you can use a "Variable" thickness floor with that approach?
Message 5 of 9
Message 6 of 9
Thanks for all the replies! The dynamo solution worked!
Message 7 of 9
 Yes, it does floors with variable thickness as well.
Message 8 of 9
Mark_Engwirda
Thank you so much for posting this link, I have been looking for a tool that can do this and it does it so easily too!
Message 9 of 9
mailler_burch
Hello guys. It doesn't work with a Civil-3D shared topography. Has anyone experienced it and could find a solution?
