Topography not being generated when exporting IFC
sam.stibbs
Message 1 of 23
sam.stibbs
I am unable to get the topography within my models to export when exporting to an IFC file format.
I have checked in the IFC options and it is set to export and tried changing the default export name but to no avail.
Any ideas on why this may be happening?
Replies (22)
Message 2 of 23
Viveka_CD
Hi @sam.stibbs
Can you share a file to test further?
Message 3 of 23
sam.stibbs
Sure, please find attached.
For reference I am using Revit 2018.3
Message 4 of 23
I was able to export your RVT to IFC and then open it intact in IFC Template.   I did notice that your Survey Point and Project Base Point are separated from one another by a great distance. 179 miles.   Revit has a limit of 20 miles. This could be related to your issue.  Close the gap and try Exporting to IFC again.
Message 5 of 23
Viveka_CD
@sam.stibbs
Please confirm if you use this exporter: https://apps.autodesk.com/RVT/en/Detail/Index?id=6193770166503453647&appLang=en&os=Win64
Als post a screenshot of your export settings.
Thanks for sharing the file and let us know if the recommendation by @barthbradley helped with your issue.
Thank you @barthbradley Smiley Happy
Message 6 of 23
Viveka_CD
Message 7 of 23
I exported it using the built-in IFC Exporter and I can see the topo when open the IFC in revit.
Message 8 of 23
sam.stibbs
I only have access through my companies IT to be able to use the in built IFC exporter. Settings export screenshot it is attached.
I don't have any issues with any of the other elements when I have been exporting them to IFC only the topography elements when I bring them into Microstation.
Is there a known issue with Revit version 2018.3.1 is this why you suggest to upgrade?
Message 9 of 23
Con you post a screenshot of the setup (via "Modify Setup")?
...built in exporter worked for me. 2018.  Did you try unclipping and moving Survey Point to the Project Base Point?
Message 10 of 23
sam.stibbs
Screenshot attached
Message 11 of 23
Message 12 of 23
sam.stibbs
I had the same in terms of those options you highlighted and tried changing the default name by adding Topography to the end to see if that might change anything but it didn't.
I have also just tried unclipping and moving the survey point to the project base point as suggested and still the same issue.
Message 13 of 23
Message 14 of 23
I exported using the default settings below.  Didn't have to change a thing.
Message 15 of 23
Viveka_CD
@sam.stibbs
Can you try as suggested by @ToanDN  and let me know if this helps with your issue?
Message 16 of 23
sam.stibbs
Ok so it is exporting but onto the IfcSite layer even though the IFC export options have it set to export onto IfcBuildingElementProxy. However, when I then attach it into Microstation it is not appearing?
Message 17 of 23
Viveka_CD
Hi @sam.stibbs
Can you share the files to test further on my end?
Message 18 of 23
@sam.stibbs @Viveka_CD
Hello Sam,
I have review your uploaded Revit File. the actual problem in your Revit file is a Toposurface Phase that you have assign in your model.
Please do following steps:
Select toposurface and in properties panel change
Phase Filter : New Construction
Phase Demolished : None
Then After try to export IFC
After Exporting IFC you can change phase again as per your requirement.
Please see attached Capture Image.
Please accept as a solution if it's work.
Message 19 of 23
sam.stibbs
The settings you said to alter are already like this in the file I uploaded so it doesn't make any difference on the export I still just get the topography border at zero level in Microstation and no contours to it.
Sam
Message 20 of 23
@sam.stibbs
please share your screen with me then only i can clearly understand and do something for you.
