Topography-Importing LandXML files
Message 1 of 18
Hello, i`m starting a new BIM project as a leading architect so i recieved point cloud surface generated by AutoCAD Civil 3D. File format is LandXML. I know revit needs a Site designer extension so i have installed it but have some problems.
Lets go step by step.
1. Lets say i open new architectural project and open site plan.site plan.JPG
2. Site Designer > Import LandXML > Positioning Auto Origin to Origin. Import Completed.
3. As u can see my topography went to origin coordinates and was far from my project base point.topo position.JPG
5. If u take top view and spot a coordinate u get this:revit coordinates.JPG
Compared to topograhy in 2D which was made with autocad u can see that revit topography is positioned corretly. Its pretty much the same coordinates begining, and number count.
6. So let say i would like my Survey point to remain 0.0.0 but my project base point to be the one i spotted in Revit topography. So i copy the same coordinates to project base point. Because revit is milimeters (mm) and civil is meters (m) i add additional 3 numbers after dot.project base point.JPG
7. After i go back to site plan and use command Zoom Fit (ZF) i see this:site plan after.JPG
As u can see my topograhpy is still somewhere in the galaxy besides the fact that i entered my project base point as the point i marked in topography. And all elevation tags went somewhere too.
Any ideas what im doing wrong?
Any help would be crucial. And sorry for my English i just started IELTS preparation class.
Eddy,
Architect
Replies (17)
Message 2 of 18
Do you have access to the source AutoCAD file?  It looks like it has a rogue element that doesn't belong in it. It needs to be deleted (cleaned up) at the source.
Message 3 of 18
Thank you for your response. I do not have autocad file, only xml. But it
cant be something wrong because its 3d scanned point cloud. My main problem
is that i cant place project base point on top of it. Can you suggest any
other options how i could do that?
Message 4 of 18
@Anonymouswrote:
My main problem is that i cant place project base point on top of it.
I am not sure what you mean by this. You got my attention though. Can you elaborate?
Message 5 of 18
What i mean is that every model ant its views moves with project base point
right? I need to move my project base point to coordinates showed in the
picture so my model also moves on top of created topography so i could make
site plan and rotate it to true north
Message 6 of 18
You shouldn't move the PBP in your project. You should move the Toposurface.
Message 7 of 18
But if i move the toposurface its coordinates wont be original, will it?
Message 8 of 18
...the Toposurface in placed in relationship to your building. That is, instead of moving Mohammad to the mountain; move the mountain to Mohammad.
Your Survey Point will establish the "correct coordinates".
Message 9 of 18
Thank you for your help, i will try your suggestion tomorrow and let you
know if the coordinates of the toposurface remained the same.
Message 10 of 18
You're thinking about this too literally. A coordinate is simply relative to something, such as a geodetic marker. The Survey Point is that geodetic marker.  If the site pad on your toposurface is suppose to "read"  500 ft. above sea level, then move your SP down 500 ft, and set your toposurface's spot coordinates' "Elevation Base" parameter to Survey Point.  See what I mean?
Message 11 of 18
Yes, i exactly know what i mean, unfortunately i have already left my
studio, so i give it a go tomorrow and post a feedback to you
Message 12 of 18
I wasn't reading all the posts so pardon me if it is already addressed.
You should import the XML and create a topography in a separate Revit model - let's call it Site model.  Then link the Site model to your Building model, move it to align properly with your building, then Acquire the shared coordinates from it.  Your Project Base Point needs not and should not be touched.
Message 13 of 18
And what about ifc export? Would ifc read linked toposurface and its
coordinates and all elements linked to it to navisworks manage viewer for
example?
Message 14 of 18
Viveka_CD
Hi @Anonymous
Can you try the below?
Import the XML file in AutoCAD  and this can be converted to objects.
Then you can do a simplify the CAD files before importing to Revit.
Message 15 of 18
example?
I don;t know about IFC but if you intend to work with Navisworks, why not export to NWC, which you can include all linked models?
Message 16 of 18
I see your point, it can be done but i would prefer to have it on one model
not two separate.
Message 17 of 18
Viveka_CD
Hi @Anonymous
Can you share the file with us?
Message 18 of 18
Yes, i will do it tomorrow.
