In my topographic plan and in almost all views I don’t want to see the topographic contour lines. How can I hide those? Is it possible? I can’t even hide those because if I try to do that the entire topo pad disappears and some elements connected to that as well. Appreciate some info.
Solved by aRcHiTeCt.JM. Go to Solution.
…. hi @Anonymous
... in any view
…. go to (VG) visibility/graphics
….. in visibility go down to topography
…. uncheck primary contours
… uncheck secondary contours
… enter ok
aRcHiTeCt.JM
REVIT EXPERT ELITE
➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ is it working for you ? ➪ ⇩ 'Accept as solution' ⇩ ⇦
