Room Tag Section visibility control
1 ANTWORT 1
GELÖST
Nachricht 1 von 2
453 Aufrufe, 1 Antwort
I have created a room tag which shows the room name and the length x width of the room ( enclosed as room tag). Also enclosed is the plan tag which shows it inserted in the plan. Now the same is also being seen in the section ( section tag). In the section I would not like the size to be seen only the room name. Can someone advice how this can be achieved?
1 ANTWORT 1
Nachricht 2 von 2
bin
als Antwort auf: Anonymous
  1. Edit the Tag family.
  2. Select the Dimension Label.
  3. Under Properties, Associate Family Parameter.
  4. Create a Type parameter.
  5. Load into your project.
  6. Edit type and create new type without the dimension.
