topo
topo
WrMcDesigns
topo
WrMcDesigns
All I want is a quick way to download topo. Does anyone know an easy solution? Infraworks requires a lot.
Bring it into Revit as a CAD Import and create Toposurface from Import Instance.
...if I've missed the mark here, please explain what you mean by "download topo".
Download from where?
rxi.gg
Hope this is what you are looking for
https://cadmapper.com/
Roi G. | AUTODESK REVIT & DYNAMO EXPERT
Da un "Me gusta" si la respuesta te ha resultado útil y acéptala como solución si ha resuelto tu duda.
Give a "Like" if the answer has been useful to you and accept it as a solution if it has solved your doubt.
WrMcDesigns
Hi. I just want to download existing, or historic topo from a site to my project.
I've never used CADMapper, but it I was I would follow this workflow:
Site Context from CADmapper to Revit (bimground.com)
Where can we assist you in this workflow as it relates to the steps that involve Revit (or AutoCAD)?  Where are you getting stuck?
WrMcDesigns
Like other add-ins there is never a smooth process. Cadmapper works but only gets down to 12' topo increments. I don't mind bringing cad topo into revit, and the process is fairly easy. There is just no direct way to get CAD topo. I also do not want to learn a Civil design program just to get topo for a site that is mostly just for rendering.
It seems like Autodesk should have an easy solution in the AEC collection that does not have me buying an add-in, or learning Civil software I would not use otherwise. I think Revit should be able to download historic topo directly from the "Project Location" dialog.
