To join Automatically floor and walls
TomasoCardia
Message 1 of 8
TomasoCardia
Hi all, How can I do to join all the walls with all the floors automatically (without to go to all single wall and "join" with his floor) ? in the picture are the structure part of the wall that is not joint with the structure part of the floor.
Thank you!
Replies (7)
Message 2 of 8
No. And it's not just a Join. It's a negative height offset from level as well.
Message 3 of 8
TomasoCardia
Captura.JPGSo to obtain this (subtract floor finishing), I have to do manually always ?
Message 4 of 8
...another approach would be to modify the structural layer of the wall to have a negative base offset on placement. It won't automatically join to the floor's structural layer, but it will contact the structural layer of the floor.
Message 5 of 8
You don't need to manually cut the floor. but you need to Attached wall base to the floor, or manually Join Geometry.  Wall core will extend to meet Floor core; Wall finishes will stop at Floor Finish.
Message 6 of 8
DUH. Attach to BASE.  My senior moment for the day -- at least I hope it's the only one.  Smiley Wink
Kudos @ToanDN
Message 7 of 8
Its a bug.
The way i fixed it is by detaching the walls from the floor, moving the floor to a different level then moving it back to the original level, then attach the wall again.
Message 8 of 8
lamquangvietthinh
Never thought one day I will have to use thisss !!! thanks !!
