Titleblock
7 REPLIES 7
Message 1 of 8
556 Views, 7 Replies
Titleblock
I seem to have a problem when I change the sheet size.
See for yourselves. I don't find the problemsome lines seem to be snapped on the left side of the sheetsome lines seem to be snapped on the left side of the sheettemplate-02.PNG
Tags (2)
7 REPLIES 7
Message 2 of 8
Looks like you've created a parametric Titleblock family and that line work that is misbehaving is simply not constrained properly.  Align and lock the end points of those line to a stationary Ref. Plane.
Message 3 of 8
in reply to: barthbradley
okay and how do I do this? The sheet is based on OOTB revit sheets.
Thanks for the help!
Message 4 of 8
Post the family. I'll fix it and return it.
Message 5 of 8
Don't make the sheets parametric...just create a new titleblock family.
It's not worth the headache.
Message 6 of 8
Thank you in advance. Sometimes revit can feel so counterintuitive... or probably my Revit knowledge isn't on point.
Message 7 of 8
I'm not readily seeing the issue you showed in your first post screenshot. In other words, I can't break it. But, if you just group all the labels, linework and logo together, that may give you better control over those elements.
Message 8 of 8
I don't know if it really is this which fixed it. I just started all over again and did the same as before. In the end i 'pinned' everything and grouped the complete title block, which seems to work.
Thanks for your time and effort!
