Titleblock Text
5 REPLIES 5
PhilvK
1417 Views, 5 Replies
Titleblock Text
PhilvK
I have created various sizes of fonts for text and labels for a titleblock family. Is there a way to copy these to another titleblock family, or do I have go in a re-create them all by scratch?
Phil
Titleblock Text
Phil
5 REPLIES 5
davidtetro
in reply to: PhilvK
davidtetro
Have you tried to copy / paste from one family to another? being that they are both title-block families, it may work. Or, you can copy and rename the original titleblock family and adjust the linework as necessary - that way, all the families are the same in both titleblock families.
scott.a.green
in reply to: PhilvK
scott.a.green
    Hello Phil,
   I would personally create a template or family for the titleblock then you can use the same properties in another titleblock and just change the text:
http://wiki.bk.tudelft.nl/toi-pedia/Create_Your_Own_Sheet_Title_Block_Family_%28Revit_Architecture%2...
First Name Last Name or First Name.Last Initial
Public Facing Job Title
Link Name | Link Name | Link Name | Link Name
    Hello Phil,
BIMologist_
in reply to: PhilvK
BIMologist_
I was looking at it as well. First I thought, why not just use Transfer Project Standards, Well guess what, you cannot Transfer the Labels and Text , other settings yes.
As Reply two suggested
Copy paste the Label and Text items from one to the other.  but this requires ALL the entries used and copy pasted.
As Scott Suggested
Creating your own TB.
Well the issue is YOU HAVE 2 title blocks I take
so why not open up TB1 (with all styles) and open up TB2.
Instead of copying the Label and Text Styles, Why not Delete the linework from TB1 and just copy Linework from TB2 to TB1, adjust as needed. Save TB1 as TB2 and off you go.
In future you CAN create a TitleBlock RFT family Template.
Save TB1 as MyCompany TB Template.RFA
close the file
In windows explorer rename the .RFA extension to .RFT
Now in future you can use that as your TB template.
hope this helps
BIMologist / Dr. Revit
Approved Autodesk Services Marketplace provider - BIM Consulting
If you find this reply helpful, please use the Accept Solution or Like button below
As Scott Suggested
close the file
hope this helps
scott.a.green
in reply to: BIMologist_
scott.a.green
Phil, Nauman nailed it. Creating a new template I think would be the best long term solution so you could have a standard titleblock template for your projects. Opening the two as Nauman suggested would be a great short term solution but you would end up repeating that process for other projects so why not save time and make a standard titleblock family. I would mark Nauman's reply as a solution. Please let me know if you have any further questions and happy Reviting!
PhilvK
in reply to: scott.a.green
PhilvK
Thank you all for your replies. They are all very helpful!
