I have created a template, and my title block is part of that template. I was sure last week I could see all the editable parameter in the title block, I could see and edit them all in the properties tab. I have created labels for everyone I want to be able to edit.
My question is, how can I easily edit the info in my title block (name, rev, description, etc.)?
Solved by corey_danielson. Go to Solution.
Solved by barthbradley. Go to Solution.
Solved by vitorbortoncello. Go to Solution.
It depends on your setup. If you can edit all the values directly in the Properties tab, it suggests that you have instance parameters in your title block families where you can type in the values. However, for example, I use Project Information in my title blocks and incorporate revision labels that are linked to the revisions schedule.
See attached example
Did you create Project Parameters using the EXACT SAME Shared Parameters that you used to create the Titleblock Labels? Did you assign these Project Parameters to only the Sheet Category (NOT Project Information)? Did you populate those Project Parameters under the Properties of the Sheet? Did you place the Titleblock on the Sheet?
