title block printed with extra space
pokoreading
pokoreading
My title sheet is created using the autocad title block. I printed the sheet, but it came out a little smaller with an extra white space surrounding the title block, so the 11x17 title block boundary is completely visible.
How can I print this title bock as normal as autocad, so there is no extra added space after the title block boundary
pokoreading
I solved the problem.
and the solution is : you should set it to "Zoom: 100%" instead (Print » "Print Setup..." button). This will yield a true-scale print
