Announcement: We’re aware of an issue affecting starting a new topic from category pages and creating new blog posts. New topics can still be started directly from the relevant board. Learn more here.
Tire wall for race tracl
Toms_Balodis
Message 1 of 21
Toms_Balodis
Is there a way to create sort of wall made from tires so dont have to place them individualy? would save a lot of time 🙂
Replies (20)
Message 2 of 21
baniabdelwaheb1
Hi Toms,
Try Curtain walls.
Message 3 of 21
FGPerraudin
Yes, just create a line-based component that repeats your tires!
François-Gabriel
Francois-Gabriel Perraudin
BIM management and coaching
Message 4 of 21
FGPerraudin
screencast to come!
Message 5 of 21
FGPerraudin
Alright, here is a screenshot of the family template you need to pick:
Here it is:
And the basic family I have created as an attachment!
You can then play with the formula to adapt the family, add another tyre to the arrayed group for two layers, etc!
François-Gabriel
Message 6 of 21
Toms_Balodis
Awsome, one more litle thing can it be made to go in arcs or circles ?
Message 7 of 21
Alfredo_Medina
Create a family with the generic model adaptive template. Create a circle, and do Create Form.
In your project, use In Place-Mass. Create a circle or an arc as a reference line. Select arc or circle and use Divide Path.
Put the "tire" family, by face, on one of the nodes of the divided path.
Repeat the "tire".
Finish the In Place-Mass.
Message 8 of 21
@Toms_Balodis
There are many ways to create it as already mentioned.  I would favor @Alfredo_Medina's divided path and adaptive family approach since it could create curved walls, even on a slope more easily.
Message 9 of 21
FGPerraudin
Yes, well it all depends on the level of BIM you want to attain.
In -place mass is a MASS, and will be treated as such.
Line based component can be attributed to a different category (furniture, etc...)
It all depends of how your model is used in the aftermath!
François-Gabriel
Message 10 of 21
Alfredo_Medina
Not really, because the "tire" can be a generic family, shared, of any category available, which can be listed in schedules.
Message 11 of 21
Toms_Balodis
Created a costume rail sistem works like a charm thank you all for the help 🙂
Message 12 of 21
Hi
Can anyone help me to stack the tyres on top of each other to create a wall for a shooting range
Please help
Message 13 of 21
Did you read any if the solutions above? They all work.
Message 14 of 21
Hi
Sorry but I'm new to revit, so I don't really understand everything, I can use the tyre file but I can't edit it
Thanks for the reply
Message 15 of 21
Do you want the tires stack or running bond?
Message 16 of 21
Stacked
I need one line of tyres 3m high and one line that is 5m high. Straight lines will be perfect
Message 17 of 21
See attached file.  Copy the curtain wall and paste it onto your model.  You can draw it in any shapes and change the height to however you want.  You can edit the tire family and give it a material parameter if you want to paint them in different colors.
Message 18 of 21
Hi
That looks perfect, this is going to sound stupid but how do I get that revit file in my existing project
Thanks again
Message 19 of 21
Open ****, select the tire walls, ctrl+c, switch to your project, ctrl + v.
Message 20 of 21
Thanks got it.
How can I change it into a straight line
