This my question and request o want to know base on model text if Revit 2021 can edit model text...
2 REPLIES 2
FacebookGroupMember
199 Views, 2 Replies
This my question and request o want to know base on model text if Revit 2021 can edit model text to curve or arch if is yes how
2 REPLIES 2
I know autocad can what about Revit
Pretty much a manual process.
Create a face based model text family with one letter and an instance parameter to edit the label and place it along a curved surface one by one (or use radial array). When done edit each instance using the instance label above. Similar approach if you want to arrange model text around a cylinder or a sphere.
Toan Nguyen
Forma Design Contest
Technology Administrators
