Notice: Upload of PDF documents is currently unavailable across the Community due to an ongoing issue.
Third Party Updater Error Message
Paul_Blanchard_Ghafari
Message 1 of 37
I am at wits end here.
Revit 2013 BSP - Structural Flavor
Revit Arch 2013
Working in the same project file. Revit BSP doesn't get the error. However, RAC users gets the follow error:
File <xxx> was modified by the third-party updater AREXRevitStart:Extensions:DReinfWall which is not installed.
If you continue to edit the file, data maintained by AREXRevitStart:REXExtension: DReinfWall will not be updated properly. This may create problems when <xxx> is later opened when AREXRevitStart:REXExtension: DReinfWall is present.
1) What is this extension? in question
2) How do I turn off this error OR how do I install the needed 3rd party extension
SEE IMAGE FOR FULL DETAILS
Accepted solutions (3)
Replies (36)
Message 21 of 37
luke.johnson
I fixed this issue by Detaching and then Saving the Central using a different filename. This caused the Do Not Warn selection to "persist" and it no longer showed.  More at: Disconnecting an API Addin or Macro Updater from a Revit Project where the code is no longer availab...
Luke Johnson
Message 22 of 37
That will only fix it for 1 project!
What about the other couple of hundred on going project files 😄
Message 23 of 37
JAndrews_TGRWA
Sasha,
I know that this is an old post, but I have recently begun having this issue.
We have several network licenses of BDSP and a couple network licenses of Revit Structure.  We had been installing BDSP at all workstations thinking that Revit would pull from either license.  As it turns out, that does not work unless we install Revit Structure instead of BDSP.  We removed teh Revit BDSP installation from sebveral workstations, we installes Revit Structure to those stations, we installed the Revit Extensions from Autodesk.  Now, when a station that has Revit Structure opens a file, we getthe error.  When a station that has BDSP open the file, we do not get the error.
Message 24 of 37
luke.johnson
Is there another addin or extension that the BDSP pcs have, that is not on the other ones? Usually, a missing addin or macro results in this error.
Luke Johnson
Message 25 of 37
sasha.crotty
Hi jandrews407,
The warning is triggering on precisely the kind of situation it is supposed to catch: that two machines are potentially going to have different behavior when modifying the model because one is missing an add-in that updates to the model based on user changes.
I think there are three options in your case:
1. Install the missing add-in on the Revit Structure machines
2. Remove the add-in from the BDSP machines and use the techniques described above to reset the file(s).
3. Ignore the error ("Continue working") on the Structure machines, particularly if those machines are not making modifications to the files (e.g. links).
Sasha
Sasha Crotty
Director, AEC Design Data
Message 26 of 37
JAndrews_TGRWA
Thanks for the input.
We have installed the REX on the Revit Structure machines.  We used the same REX intallation for Revit Structure and BDSP.  I guess the question is - Does BDSP install something else as part of the install?
I can't do 2, too cumbersome with teh quantity of projects.
I can do 3, but I really don't like getting into teh habit of ignoring errors.
Message 27 of 37
sasha.crotty
What is the exact add-in that's being reported in the message? I will ask someone that team to take a look.
Sasha
Sasha Crotty
Message 28 of 37
JAndrews_TGRWA
Here is a screen shot.
Message 29 of 37
My experience has been that it is the structural reinforcement tools that are part of the Revit Extensions
Message 30 of 37
luke.johnson
I wonder if something changed between REX versions, leaving this issue after upgrade? Did you install the exact same Extensions package on both workstations?
Luke Johnson
Message 31 of 37
JAndrews_TGRWA
I did install the same REX version in each case.
Jon D. Andrews, S.E.
Principal
TGRWA, LLC
600 W. Van Buren, Suite 900
Chicago, IL 60607
p. 312.341.0055x204312.341.0055>
d. 312.341.1102312.341.1102>
f. 312.341.9966312.341.9966>
c. 773.793.5601773.793.5601>
[email protected]>312.341.9966>312.341.1102>312.341.0055>
Message 32 of 37
JAndrews_TGRWA
Principal
TGRWA, LLC
Chicago, IL 60607
Message 33 of 37
dkwolek
Hi
It happens that file saved with Revit and opened with Revit Architecture, Revit Structure or Revit MEP causes the warning about Missing Third Party Updater to be shown.
In this case it is perfectly safe to choose “Do not warn me about this updater again and continue working with the file.”
If the file is central I suggest opening it with option “Detach from Central”, choose option “Do not warn me…” and save again as a new central file using computer with not installed Revit Extensions.
After saving recreate all local copies of project on all machines.
Additionally there is an option to turn off Dynamic Model Update mechanism on all user machines by choosing Extensions->Preferences->
Dynamic update->Uncheck “Turn on dynamic model update”.
This will assure DMU not to be used and cause warning any more.
Hope that helps
Dariusz Kwolek
Structural Product Manager
AEC Solutions
Message 34 of 37
Worked for us/
Message 35 of 37
richardbeatson
We've just had this issue in the office. Re-creating the central model solved it for us.
http://whatrevitwants.blogspot.co.uk/2014/01/disconnecting-api-addin-or-macro.html
Message 36 of 37
jperkins1MXXNE
And.. here we are in 2020 with no solution and the same problem:
so do we continue to ignore it or will it get fixed ?
Message 37 of 37
omarselim
until now not solved
i send to third party and the replay "
This is a non-issue, just temporarily annoying, the client can use either of the top 2 options to continue working on the file without issue.
It is just a common glitch of the Powerpacks.
BIM manager with 19 years of experience.
The Universitat de BarcelonaThe Universitat de Barcelona
Master in Global BIM Management for Infrastructure Projects
Research Assistant at Qatar University
being honoured at Autodesk Digital transformation summit for the Egyptian government, for spreading and supporting the BIM culture, and community development regarding the digital transformation of the construction sector
General manager of BIMarabia Research, BIM Dictionary's
