Thick lines overlapping with symbols in vector export
pablo.odriozola
pablo.odriozola
Hello everyone,
I am forced to export my plans in raster quality due to the poor visibility when using the vector option. My main concern involves thick lines (both Model and Detail lines) overlapping with symbols. It seems as if the thick lines are trimmed where they overlap with the symbols. This approach works with thin lines, but with thicker lines, the rounded edges extend further and overlap with the background color of the symbols as seen in the screenshot.
Is there anything I could set up differently when exporting the plans as vector?
Alternatively, is there anything I can change in the symbol so that the background color stays on top of the lines as well?
Thanks for any feedback!
Regards, Pablo
vitorbortoncello
Instead of using such a thick line, use a filled region with invisible line edges. I think it will be easier to control that issue this way.
A resposta te ajudou? Não esqueça de curtir e aceitar como solução!
Vitor Bortoncello | Arquiteto | BIM Manager
dAutodesk Certified Professional
mhiserZFHXS
Shoot this idea a vote. Round ends are fine 90% of the time, but there should really be an option for various line ends.
https://forums.autodesk.com/t5/revit-ideas/line-end-style-2d/idi-p/6330283
