There in so sync - from Revit 2021 to Navisworks
when i click refreshes in navisworks manage 2019  i can't see the part of the model i have been added from revit 2021? there is no sync, and the model in navis doesn't update.
Rafal.Gaweda
Autodesk Support
Autodesk Support
Hi @Anonymous
If You mean Switchback option, this works between products of the same version:
Revit 2019 <-> Navisworks 2019
Revit 2020 <-> Navisworks 2020
etc
Rafal Gaweda
Samantha-G
Hi @Anonymous
Did you check under external tools?
Sam G, CM-BIM
Revit Certified Professional
yes, but when i change walls in Revit model i can't see the update in Navisworks
