Message 1 of 9
Hi all ,
I want to model such a floor. Do you suggest to model it in one piece or in keys?
Hi all ,
You can do it by either:
Using the Add Split Lines tool. Select the floor > Go to Modify > Add Split Lines.
This will be tricky but i think it can be done.
Or you can model the floor in place. This will be easier.
You have to decide wich will be best for your project
Tried. Too many internal line and consequently sloped arrows
Use modify sub elements, you can model it in parts if the geometry gets too complex.
Possibly some alternatives I could think of; (to place it as adaptive component in) model in place [floor] or perhaps model as roof (by (mass) face), but I would go with first mentioned 🙂
Hi is it modelled as one floor ?
yes, as a single Roof/Floor , by using Shape Editing >Modify sub Elements
Constantin Stroescu
May you please make a short video and I will accept a solution.
I hope it will help you:
https://knowledge.autodesk.com/community/screencast/a8f99c77-1d13-427b-9de1-e7903f478495
Constantin Stroescu
