when i click refreshes in navisworks manage 2019 i can't see the part of the model i have been added from revit 2021? there is no sync, and the model in navis doesn't update.
Gelöst! Gehe zur Lösung
Gelöst von Rafal.Gaweda. Gehe zur Lösung
Hi @Anonymous
If You mean Switchback option, this works between products of the same version:
Revit 2019 <-> Navisworks 2019
Revit 2020 <-> Navisworks 2020
etc
Hi @Anonymous
Did you check under external tools?
yes, but when i change walls in Revit model i can't see the update in Navisworks
