The ViewCube on Revit 2025 is missing
cristel-m_batista-o
Message 1 of 15
cristel-m_batista-o
I just downloaded the program, haven't made any changes to it, and the view cube doesn't appear anywhere. Its as if the option is blocked or something. I wish to fix this ASAP, I'll put an image onto how the options on the program interface appear (it´s in spanish).
Replies (14)
Message 2 of 15
RSomppi
Are you in a 3D view?
Message 3 of 15
cristel-m_batista-o
No, just the default page when you start a project.
Message 4 of 15
RSomppi
Have you tired it in a 3D view?
I don't know what your default page is, but you won't see the view cube (or have the option to turn it on) unless you are in a 3D view.
Message 5 of 15
cristel-m_batista-o
Thank you so much, I'm new to this software and it has so many features that I still need to learn more about the basics.
Message 6 of 15
smayPJRZF
If you activate the 3D view from the sheet view, the view cube doesn't show up. It did in previous versions of Revit. Now, in 2025, it only shows up if you open the view directly from the browser. It is cumbersome to have to open the view directly when you need to make minor adjustments to the view orientation regarding its placement on the sheet.
Message 7 of 15
kknickerbockerU7SP9
Observer
Observer
This is a topic that's been discussed between a coworker and I. It's beyond cumbersome, it's a genuine step backwards in productivity and workflow. Unless this is just an options setting now, it seems redundant to remove a feature that was genuinely helpful.
Message 8 of 15
RSomppi
How did you determine that it was removed as opposed to it being something in the options?
Message 9 of 15
kknickerbockerU7SP9
Observer
Observer
I did not determine it as such, I was speaking speculatively. If you know if it is indeed an option that can be enabled/disabled, I would be glad to know!
Message 10 of 15
RSomppi
Redundant? What did you really mean to type there?
Message 11 of 15
blank...
We expect discussions to stay focused on the topic at hand. Criticizing someones English—when it’s not their native language—is neither helpful nor constructive, and we would appreciate it if you directed your comments accordingly.
Message 12 of 15
RSomppi
We? Maybe if "we" would recognize that it was a simple question, "we" wouldn't be playing moderator, would "we"?
Message 13 of 15
blank...
In my country royal plural is used for monarchs. Sarcasm doesn’t change the fact that personal criticism, either about language skills or the proper way to address, is unnecessary and off-topic. If you have something constructive to add to the discussion, we’d be happy to hear it.
Message 14 of 15
RSomppi
I was simply asking for clarification. Anything more than that is all in your perception. You obviously have some sort of made up personal issue to be coming at me like this. Might want to check that at the door.
Message 15 of 15
RDAOU
Hi @cristel-m_batista-o
Did @RSomppi REPLY HERE suggesting to check this option when in a 3D view help you solve the issue? please mark it as a solution to close this thread
