The shadow wasn’t show on the entire model
Message 1 of 12
thank you of your time,
I use revit to show the shadow analysis, when i tern the shadow it didn’t show the entire building, it only show in some of them. So what should i do to fix this please.
Replies (11)
Message 2 of 12
can you show a pic?
Message 3 of 12
Message 4 of 12
Yes
Message 5 of 12
Message 6 of 12
Are those other buildings 3d too?
Message 7 of 12
Yes
Message 8 of 12
See below and choose the proper level as the Ground level.
Message 9 of 12
I don’t have it
Message 10 of 12
I only have level 1/ and level2
Message 11 of 12
First, uncheck the box see if it works. It may if you modeled the ground in 3D. If not, open a section and add a Level where your ground plane is.
Message 12 of 12
It’s work thank you sooooil much
