The same floor but different display
ngomanhhabkhn
ngomanhhabkhn
Hi Team member,
I have the same floor and I apply for the same template view. But the view is different. Could any one let me know what is  the reason of this problem.
Is the view range box check led in the view template settings?
Is there a plan region in that area?
Maybe there is a Plan Region for that one area that is showing.
Actually, I see a lot of differences between the two Views.  Does your Template govern every single setting?  I bet not. There are Overrides that have Hierarchy over VTs as well.  Here's a one-sheet that explains:
https://knowledge.autodesk.com/support/revit/learn-explore/caas/CloudHelp/cloudhelp/2020/ENU/Revit-D...
ngomanhhabkhn
I found the reason of this problem. Because the plan have a floor when I selected " Hidden line" in view. The floor occur the structure at basement. So we need to check box Model in view template and select wireframe to see the under floor. Otherwise, we need to uncheck the floor in view template.
Or we turn off the floor
