Announcement: We’re aware of an issue affecting starting a new topic from category pages and creating new blog posts. New topics can still be started directly from the relevant board. Learn more here.
the quickest way to edit 3D mass
l.yong1
Message 1 of 14
l.yong1
Hi there,
Does anyone know the qucikest way to edit 3D mass form? I have 24 segments form. Need to edit the width, length and height? 24 different looks.
Please see attached screenshot.
Thanks Lilian
Replies (13)
Message 2 of 14
RDAOU
@l.yong1
Why not upload it to see how it was modeled and what may be done with it
Message 3 of 14
l.yong1
Hi RDAOU,
Thank you for your reply.
I used Inplace mass, ref plane to create this form. There are 24 segments not indentical. Wonder anyway I could edite each of them faster? How about dynamo?
Message 4 of 14
Model it as a family with instance dimension/angle parameters so that you can change them in project.
Message 5 of 14
l.yong1
Thank you Toan. Can you please demonstrate an example?
Message 6 of 14
RDAOU
@l.yong1 wrote:
Hi RDAOU,
@l.yong1
There are several ways and yes dynamo is one if you wish to use dynamo. But I asked you to upload the family because I did not want to type too much. It would be easier and faster to demonstrate it in a GIF...And visual tutorials are easier to follow
Message 7 of 14
mhiserZFHXS
There are loads of resources on how to create parametric families. Check out YouTube.
Message 8 of 14
@RDAOU wrote:
@l.yong1 wrote:
Hi RDAOU,
@l.yong1
Edit:  sorry this is supposed to be for @l.yong1
See attached 2022 file.
Message 9 of 14
RDAOU
why am I being quoted?! 😆
Message 10 of 14
l.yong1
Hi Toan,
Perfect. I think you understood my question. I created these 3D mass using my origami model.
I have shared a few of them with you. There are 24 segments. I need to adjust the height, width in a smart and effeicent way. Please see attached file.
Thank you. Have a great day😄
Message 11 of 14
l.yong1
Hi Toan,
Can you please tell me which family template did you use? I used family generic model template but I cannot adjust the height, width, angle.
Thank you😎
Message 12 of 14
@l.yong1 wrote:
Hi Toan,
Thank you😎
Did you open the file attached?  I use Generic models family template but it doesn't really matter.  Most if not all family templates will work.
Message 13 of 14
jainsrashti15
  • To access the Conceptual Mass panel, go to the Massing & Site tab (In-Place Mass).
  • Click OK after giving the in-place mass family a name. The conceptual design environment is displayed in the program window.
  • Using the tools on the Draw panel, create the desired shapes.
  • Click Finish Mass after you're done.
For deep learning of Revit Architecture, you should go through the Revit Architecture Training in which you can learn all the concepts from basics to advanced.
Message 14 of 14
l.yong1
Thank you. You are amazing. Have a great day:)
