Retaining Footings for a Basement Floor Plan.
ian.felix1032
ian.felix1032
Struggling to put wall (retaining) foundations underneath this floor plan. It won't even select the wall to attempt to place the retaining footings underneath. The flooring is just a 10'' wood joist with a wood finish, however, the structure is concrete with a wood finish. I don't know how to place the retaining footings down, can anyone help?
Draw retaining walls underneath the exterior walls where required and place wall foundation under the retaining wall.  You may need to create a plan view cutting the retaining walls then make the task easier.
