The plans are not exporting they way they are supposed to
12 ANTWORTEN 12
Nachricht 1 von 13
845 Aufrufe, 12 Antworten
I've been exporting plans from this Revit file for over a month now, just yesterday after adding some furniture elements and I downloaded furniture and linked them to the file, the plans have been exporting with the columns rotated and large grey squares spread across. Please could anyone help me?
I attached a pdfs of before and after.
12 ANTWORTEN 12
Nachricht 2 von 13
als Antwort auf: Anonymous
What do you mean by "Exporting Plans from this Revit File"?
Nachricht 3 von 13
amdesoky87
hello,
check that you turned the shadows off
Nachricht 4 von 13
als Antwort auf: amdesoky87
They are turned off I checked
Nachricht 5 von 13
als Antwort auf: barthbradley
I mean my Revit file.
Nachricht 6 von 13
EXPORTING to what?  IFC, DWG, ETC?
Nachricht 7 von 13
Exporting to PDF
Nachricht 8 von 13
You mean PRINTING to PDF?
Nachricht 9 von 13
Yes
Nachricht 10 von 13
Okay, so now that we got that straight, what's the problem again?  Printed output is not the same as what's shown on the screen?
Nachricht 11 von 13
Yes exactly, the preview of the printed output on Revit shows the plan normally, however when it is printed to pdf and I open the file, it is found like the file I attached above. I have no idea where these grey overlaying shapes came from and also the columns' alignment is messed up.
Nachricht 12 von 13
Nachricht 13 von 13
syman2000
What PDF are you using? If you are using Adobe PDF, I would set the 1200DPI export to 600 or 300DPI.
