Message 1 of 15
The minimum thickness of the lines, when exported as PDF, is 0.085, not 0.025.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
*Edit: I tried exporting from Autocad to PDF as a test. The line thicknesses are respected. Even the minimum thickness of Autocad, 0.05 mm is exported correctly (it becomes 0.047...). So it's a problem with Revit or my Revit.
Good morning.
I am exporting a plan view in vector format as a PDF. I created the various thicknesses from "line thicknesses", based on the scale. I realised that in PDF Revit does not export lines with the minimum thickness, 0.025; not even 0.026, 0.027, etc. The minimum thickness of the lines, when exported as PDF, is 0.085.
Does this only happen to me? Can I solve it somehow?
Thank you.
