the hatch of the floor doesn't show up in Revit
8 REPLIES 8
Message 1 of 9
Yara-architecture
8960 Views, 8 Replies
Hello, I have this issue in Revit, the hatch of the floor on the first floor, it shows up in 3D but in 2d plan doesn't show up how to fix that? thank you in advance.
8 REPLIES 8
Message 2 of 9
Could be any number of reasons.
Betcha it's one of these 33:
https://www.ideateinc.com/blog/2013/01/missing-something-in-revit-view-33
or, you can post the file.
Message 3 of 9
I will check that out and let you know if the problem solved, thank you for the answer
Message 4 of 9
I attached the file if you can see how to fix that? thank you
Message 5 of 9
The View is set to Realistic. Material Graphic Tab settings do not show in Realistic. Realistic and Rendering use the settings found under the Appearance Tab of the Material - which in this case is Porcelain.
Message 6 of 9
thank you so much for your help,  the problem is solved
Message 7 of 9
Hey @Yara-architecture : I notice you have a Graphic Override for the Floor's Surface Pattern in 2D Floor Plan. You are adding Vertical Lines. You can modify your Floor's Porcelain Material to show the same in Realistic.
Message 8 of 9
oops, you probably need to know how I get there.
Message 9 of 9
thank you so much for the information very helpful.
